User16787
The detail system messages are shown below.
"Initializing Driver board eeprom:...........[NOK]
Board pre-initialization..............[NOK]
Error: No file system loaded"
I look forward to get help from the forum or Infineon.
3726.attach
User16787
Hi, Infineon Engineer.
It is very important to me to reply it, Please help me on it.
Thansks,
best regards.
rodger.zeng
User16787
Thansks,
best regards.
rodger.zeng
RValascho
5 questions asked First question asked 10 replies posted
Hi Rodger,
There are several combinations of boards, so the kit uses the EEPROM to identify what is present at that time. The message you are getting is because these EEPROMS are either blank or corrupt. Included in the kit should be instructions on how to re-program the EEPROMS (one on logic board, and one on gate driver board). Once a valid configuration is loaded in the EEPROMs, then you will clear this init problem.
