AURIX™ Forum Discussions
i need program an micro TC264DE with the DAP mini wiggler, but i don't find the target configuration file (.cfg).
Which file cfg i need use?
Also i program by JTAG connector but i don't know how configure Memtool 4.7, can you help me please?
User12775
You should start from the default configuration for Appkit/Triboard.
In most situation, you don't need to write a new configuration from scratch.
