AURIX™ Forum Discussions
ASUS
5 replies posted 10 sign-ins First reply posted
My TC377 debug port is locked because of protection, I want to downloading a program to release this protection. I can set HWCFG to Bootstrap mode, and I know select BSL/ASC mode in Memtool, but I don't know how to set communication between TC377 and Memtool in Bootstrap mode.
Does Miniwiggler support CAN/LIN communication of Bootstrap mode? If not, what should I do?
ASUS
ugo_8a
10 solutions authored 25 sign-ins 25 replies posted
Hi, I  made a quick guide how to use the BSL with UART, so basically you only need a COM port (RS232) and access to pins 14.0 and 14.1.
check the attached document.
ASUS
Hi, ugo_8a
Thank you for your reply. I am using a self-made board without UART, could you please tell me how to access to pins 14.0 and 14.1 via RS232? Is it like that?
Best Regards
ASUS
ugo_8a
Hello, if you have a RS232 transceiver in the target board , yes you can connect as you shown in the diagram. if you do not have a transceiver you need to use an adapter (UART to 5v/3.3) take a look at this adapter:
https://www.amazon.com/HiLetgo-FT232RL-Converter-Adapter-Breakout/dp/B00IJXZQ7C/ref=sr_1_4?keywords=...
ASUS
Hi, ugo_8a
Thank you, I'll buy it and have a try.
Best Regards
Thank you
