How to unlock TC234 UCB_DBG via memtool
lanb
10 sign-ins 5 sign-ins First reply posted
Dear ,
OEM ask we lock MCU when SOP.
By following this thread:
Password Protected JTAG Flashing Query - Infineon Developer Community
I tried lock debug port by configure UCB_DBG via infineon memtool , it worked as expectlly;  but when I tried to connect MCU via memtool again with password it not worked.
But I can lock/unlock MCU via lauterbach successfully.
this is not a good way for aftermarket.
Could you please tell me the correct steps or configuration to unlock debug inteface with password via memtool;
Memtool information:
Version 2021.08
Build 5012
Fronted version 1.24.8
server version 1.40.12
thanks for your support.
Di_W
500 solutions authored 1000 replies posted 250 solutions authored
Hi lanb,
Thanks for your patience, as Infineon MemTool is provided by PLS. Please request support from PLS (support@pls-mc.com )
dw
Di_W
Hi Lanb,
Have you tried below action? Unlock the device using memtool with password:
https://community.infineon.com/t5/AURIX/Password-Protected-JTAG-Flashing-Query/m-p/319730#M5587
dw
lanb
Hi dw,
Thanks for your response.
I tried that steps but can not unlock micro,I am sure the password is correct because MCU could be unlocked by Lauterbach,
For locking by memtool , it's OK
Select target as below shown
Is there any configuration or step need to confirm?
Thanks & Regards,
Lanb.
Di_W
Hi Lanb,
Is your device still alive? And currently you mean the device can be unlocked for DBG by Lauterbach and not Memtool with same password.
I will report to internal if you confirm.
lanb
Hi dw,
"Is your device still alive? "
Hardware is ok after unlocking via Lauterbach.
"And currently you mean the device can be unlocked for DBG by Lauterbach and not Memtool with same password"
yes.
Thanks for your support.
lanb
Hi dw,
is there any news?
thanks & regards.
Di_W
Hi lanb,
dw
