Oct 07, 2022
02:47 AM
Oct 07, 2022
02:47 AM
Hell Aurix member,
My requirement is to trigger the ADC interrupt if value reaches the boundary values after conversion
e.g: Analog input 0 to 5
now ADC should trigger the interrupt if value reaches below 1 or above 4.
Is it possible with to trigger it with boundary values in Aurix TC3xx?
07:04 AM
Oct 07, 2022
07:04 AM
Could you check the section "32.7.3 Compare with Standard Conversions (Limit Checking)" in the document AURIXTC3XX_um_part2_v2.0.pdf?
Best Regards.
07:04 AM
Oct 07, 2022
07:04 AM
Best Regards.
