AURIXtc33x
we found this but we need more clarification for example :
we need to test the MC1 (SFI F2S ) and MC2 (CPU0) , so how we can inject non correctable error for them ?
or there is another way to inject the fault for them to be able to test their interrupt .
Hi, Marwaaboelamay
As user manual said, if the data phase(Read/write) is invalidated, the MCI or SCI will send an invalid transaction ID, so we can inject a non-correctable error into RAM , then readback the error RAM.
HOW TO INJECT THE ERROR
You can modify the ECCMAP bits to introduce multi bits by programming a word with wrong ecc.
ECCMAP = 01b, Test mode
as you see in the screenshot , i cannot access any of MTU or SRAM registers during the SW running because it goes to SW reset once open any of these registers so how can i odify the ECCMAP bits?
Hi, Marwaaboelamay
I don't know why you can't watch these registers.Is it same effect(reset) when you watch other registers?
Additional, the MCi_ECCS register is protected by End-Init mechanism, so you can't modify directly in debug.
no i can watch other registers except MTU and SRAM registers,
so how can i modify the MCi_ECCS?
Hi, Marwaaboelamay
>>I can't explain it, maybe you could contact your FAE for supporting;
>>You could reference "The Endinit Functions", before you modify the registers protected by Endinit, you should unlock first and lock it after you modified. It's a HW safety mechanism to avoid unintended modify.
