Vamshi_V
5 sign-ins First like given First reply posted
is it possible to switch to supervisor mode from user mode so that we can do certain task in supervisor mode and switch back to the user mode. If possible can anyone tell me the ways do that ??
@User22023
@indra @Aishwarya
Di_W
There is no sample code available for this specific task, but I have received information on enter supervisor mode by trigger a trap using the SYSCALL instruction. To implement it, you should refer to ifxcpu_trap.h.
Di_W
Once the system starts up, the supervisor mode is enabled.
Vamshi_V
Hi, @Di_W thank you for your reply but I need to switch to the supervisor mode from user mode in the middle of an application.Can we do that?
Di_W
Can you explain how to switch to user mode using your code? Typically, the PSW is set while in supervisor mode.
Vamshi_V
Yes, that's what we do to switch to user mode initially when it is in supervisor mode
Ifx_CPU_PSW psw;
psw.U = __mfcr(CPU_PSW);
psw.B.IO = 0x1;
__mtcr(CPU_PSW , psw.U);
This is the code that I use to switch to user mode but we cannot access the PSW register once we shift to the user mode right that's where the real problem comes.
Di_W
