Dear all,
How to set output format to binary in BIFACE?
The currently shows *.elf and *.hex under the directory "2_Out\Tricore_Gnuc" (see output_file_format.png)
You can use the following option that works with Hightec compiler:
tricore-objcopy [options] <infile> <outfile>
Please find the description of the same from the users' guide below:
tricore-objcopy can be used to generate a raw binary file by using an output target of "binary" (e.g., use -O binary)
Prudhvi.
Prudhvi.
Hi Prudhvi,
Use the command below,
the converted binary file size is too big, about 756M bytes , is that make sense? thanks.
tricore-objcopy.exe -I ihex -O binary TC39B_Tc.hex TC39B_Tc.bin
