May 06, 2020
08:50 AM
May 06, 2020
08:50 AM
Hello Support,
GxTRCTR.ITSEL bit doesn't select Q2 as request trigger source. It is only possible to select Q0 and Q1.
Please provide me some lead how to select Q2 for Group Conversion in EVADC of Aurix2G.
Best Regards
Best Regards
09:05 AM
May 06, 2020
09:05 AM
What are you trying to do? ITSEL is for causing an internal trigger when a conversion sequence on Q0 or Q1 completes. You can't cause the same type of internal trigger for Q2, but you can trigger Q2 manually via TREV=1, from the timer unit, or from many other external triggers. See 32.5.1 Queued Source Operation for details.
Feb 03, 2023
07:14 AM
Feb 03, 2023
07:14 AM
Hello All
I am using Queue 0, 1 and 2 for the same group using sw trigger method.
but queue2 is not working when i configure to trigger same queue1 and queue2 in sw trigger
only one queue is working and another is not working
