I want to use Erika on TC397_TFT board. But I didn't find sample project. Could you please help me?
AURIX
Hello dw,
Thank you for quick response. I have myICP account, I searched this application note "Integration of ERIKA OS to TC3xx Base Templates For TC3xx BIFACES Base Template Projects". but I didn't see it. Could you help me please?
Hi MTGirgin,
You can search BaseProjects_TC3xx_V1_0_1_13_0_Package.zip
dw
Hi dw,
Thank you for your quick answer. This example code is for Erika-2 operating system. Where and how I find the example/sample code for Erika-3 operating system? Could you help me please?
Hi MTGirgin,
For Erika Enterprise RTOS v3 , please consult https://www.erika-enterprise.com/ for support on commercial version.
dw
Hello dw,
I tried using Erika-3 but without success. I have implemented the step by step in this link (https://www.erika-enterprise.com/wiki/index.php/Quick_start_guide) But I have a mistake, I have shared an error picture for you. Can you please help?
MTG
Hi MTGirgin,
Below is FYI.
https://www.erika-enterprise.com/wiki/index.php/Infineon_Tricore_AURIX_build_with_RT-Druid
For erika v3, please contact the company Evidence for support.
https://www.erika-enterprise.com/index.php/support/commercial-support.html
Evidence's Technical support includes (and it is not limited to)
- porting ERIKA Enterprise to new microcontrollers;
- definition of an embedded application architecture from functional to firmware level;
- migration of existing OSEK/VDX applications to single and multicore architectures;
- integrating of customer applications with Erika Enterprise;
- integration of automatic code generation tools inside the application development flow;
- identification of the timing bottlenecks of a real-time concurrent application based on Erika Enterprise;
- development of simulation and control applications for motor control and other control fields.
dw
Hi dw,
Thank you for your help.
MTG
Hello dw,
I builded with RT-Durid for infineon tricore at eclipce like this link.(https://www.erika-enterprise.com/wiki/index.php/Infineon_Tricore_AURIX_build_with_RT-Druid)
You sent me erika-v2 sample project and document (You can search BaseProjects_TC3xx_V1_0_1_13_0_Package.zip) from Collaboration platform. Do you have document for erika-v3? How I use this erika3-os files with infineon example code? Could you help me please?
Hi MTGirgin,
For erika v3, no example code so far. Probably need to do migrate yourself.
dw
Hi dw,
Thank you for information.
Have a nice day.
You are welcome.🙂
