I am trying to set sbc to sleep mode but i guess due to the current value sbc switch wake state directly. To be ensure i try to read the wake up reason from WKSF register especially i want to check the current monitoring bit value. But the value of all bits are 0. How to read register value properly?
Thank you.
AURIX
This is a type R2 register. This register will be reset only in case of FAILSAFE, STANDBY, and a POR.
Are you moving to any of the above states?
I have checked this in the Eval board and given below the SPI log. Here I can see wake-up event happened due to the QUC current monitoring.
Vishnu N
Vishnu N
