Winnie
i need to place a section in flash0 0x81000000, and allocate specific user function into it.
i just add following code into .lsl file:
section_layout :vtc:linear
group (ordered, run_addr = mem:pfls0[0x01000000])
reserved "MY_RESERVE" (size = 16k);
group SPECIAL_FUNCTIONS ( ordered, contiguous, run_addr = mem:pfls0[0x01000000])
select ".text.canids.hello";
but, the compiler reports errors as : "syntax error: absolute location in memory for group does not map to space mpe:vtc:linear"
how should i do? or is there another method to asign flash section?
User13836
Level 6
Level 6
50 likes received 50 solutions authored 100 sign-ins
I suppose there is a typo in the address offset value. Instead of using offset 16 MB within segment 0x8 where no physical on chip memory does exist you probably want to use offset 0x100000 (1MB) instead where pflash0 memory does exist.
In addition if you want to place a section within a reserved range, you need to permit this use case by adding alloc_allowed=absolute to the reserved entry.
Plesae try:
group (ordered, run_addr = mem:pfls0[0x00100000])
reserved "MY_RESERVE" ( alloc_allowed=absolute, size = 16k);
group SPECIAL_FUNCTIONS ( ordered, contiguous, run_addr = mem:pfls0[0x00100000])
Ulrich Kloidt
TASKING tools support
MoD
50 likes received 500 replies posted 100 solutions authored
Why you will place anything in this region? Finally this region is not readable and writeable. Any access will result in a bus error.
Winnie
Thank you for your reply!
I need to update TC397 specific pflash section through the CAN bus to achieve some code update.
I refer to the following guidance to modify the lsl file:
OR is there a flash area reserved for users in TC397?
Di_W
or you can decrease the 0x100 0000 to retry.
Can you try this code?
Di_W
@User13836 Could you please have a look? Thanks!
User13836
Level 6
Level 6
Plesae try:
Ulrich Kloidt
