AURIX™ Forum Discussions
User17615
First like received
How to locate Interrupt Vector table in RAM when using Tasking compiler?
#8042000 12008
User17614
a change to the default Tasking*inttabx.lsl linker file has to be made. you have to add the "copy" keyword: it tells to copy the section from ROM to RAM at program startup.*Any locally found lsl will override the Tasking directory includes.* You need to add the “group(copy)” identifier and enclose the table entriesYou also need to change the start location in*the project linker script,.* Thanks,
