AURIX™ Forum Discussions
User18303
Hi all,
How to inject faults (Single, Double and Multi) in Pflash on AURIX™TC2xx microcontrollers ?
Lina
#8042000 13166
User18237
Hi Lina,
You can inject faults in PFlash following this method:
1- The ECC code causing the required error type (e.g. triple-bit error) can be determined
by first programming the data with automatic ECC generation on.
2- Read this programmed data to find the corresponding ECC code in ECCRPp.RCODE.
3- Switch OFF automatic ECC generation: ECCW.PECENCDIS = 1.
4- Write the value of ECC code (obtained in step 2- in in ECCRPp.RCODE) into ECCW.WCODE.
5- Now, generate the bit errors in the data to program by setting additional bit(s) in the read data.
6- Reprogram the page with this data.
Mr. AURIX™
