AURIX™ Forum Discussions
miao
10 sign-ins 5 replies posted First reply posted
    I enable MAC timecstamp but get tx timestamp always 0.
    Could anyone tell me how to get tx timestamp after send ptp pack over ethernet?
Thank you
dw
Hi miao,
Attached is geth demo code for timestamp enabled.  Please refer to it.
dw
dw
Hi miao,
dw
rpk
First reply posted Welcome!
I too am in the process of enabling time stamping on the Aurix TC3XX. In the example you provided I saw a comment that mentions
System Time Update logic requires a 50-MHz clock frequency to
achieve 20-ns accuracy, 50MHz clock is internal to GETH-IP
Does the mean that the PTP system clock will always update at 50MHz - i.e the System Time Nanoseconds register will accumulate the value from Sub-Second Increment register (SSINC) at 50MHz?
Is it possible to change the update frequency to a value other than 50MHz, and if so how?
dw
Hi rpk,
AURIXTC3XX_ts_V1.3.0.PDF
You can check 36.2.2.4 Time Stamp Error Margin and 36.2.2.5 Frequency Range of Reference Timing Clock.
dw
rpk
Hi dw,
Appreciate the quick response. How can I gain access to the doc you mentioned?
dw
