Oct 28, 2020
10:22 PM
Oct 28, 2020
10:22 PM
Hello friends,
I am using the SAK-TC387QP target board for an internal project.
I am unable to flash the program permanently. I can only use it for debugging purposes.
Now I want to flash the code permanently in my target board and make it run for all time.
Any help will be appreciated.
Thanks in advance.
Thanks in advance.
Labels
12:47 AM
Oct 29, 2020
12:47 AM
You need to change the linker file to target flash memory instead of SRAM.
Otherwise, you can use the AURIX Development Studio (it is completely free!) to develop your project, where by default the projects are stored in the flash memory of the device, making them "permanent".
You can download it here: AURIX™ Development Studio and get inspired by numerous Trainings from here: AURIX™ Trainings.
If you are not familiar with Eclipse based IDE’s checkout the Getting Started guide!
Hope it helps,
teoBits
Hope it helps,
teoBits
Nov 06, 2020
02:51 AM
Nov 06, 2020
02:51 AM
Right-click the project, Build Configurations -> Set Active -> iROM.
Rebuild and you'll get a hex file to flash.
