Dear sir,
In AURIXTC3XX_um_part2_v2.0.pdf, there is a description about : In multi queue/channel configurations, enable only Q0/CH0 on Tx and Rx for half-duplex operation. If you want to enable single queue/channel in full-duplex operation, any queue/channel can be enabled.
Could you please teach how to implement this?
BR,
SeanWu
Weikeng Inc.
You can refer to the Ethernet_1_KIT_TC397_TFT example in "Aurix Development Studio." You can also refer to the API IfxGeth_mac_setDuplexMode() in ILLD.
Best Regards.
In this example, just enable Q0 and CH0. Is it not half duplex mode?
BR,
Sean Wu
Hi Sean,
No, the duplex mode is only set by below code for your reference.
void IfxGeth_Eth_initModuleConfig(IfxGeth_Eth_Config *config, Ifx_GETH *gethSFR)
IfxGeth_Index gethIndex;
gethIndex = IfxGeth_getIndex(gethSFR);
const IfxGeth_Eth_Config defaultConfig = {
.gethSFR = NULL_PTR,
.phyInterfaceMode = IfxGeth_PhyInterfaceMode_rmii,
.pins = {
.rmiiPins = NULL_PTR,
.rgmiiPins = NULL_PTR,
.miiPins = NULL_PTR,
.mac = {
.duplexMode = IfxGeth_DuplexMode_fullDuplex,
Hi dw,
So, the setting means the ethernet is now in full duplex mode?
Could you please help to explain the meaning?
BR,
Sean
Hi Sean,
From my understanding,(1) if use half-dublex, enable Q0/CH0;(2) if use full-duplex, any queue/channel can be enabled.
dw
Hi dw,
If use half duplex mode, just can enable Q0/CH0, right?
If use full duplex mode, if I just only enable Q0/CH0, it is still full duplex mode, right ?
one DMA channel just can map to one Queue, right?
If I use one DMA channel(CH0), but use two Queues, and two Queues are mapping to DMA channel 0, is it right?
BR,
Sean
Hi SeanWu,
From my known, please consider full-duplex in your protocol stack as this is commonly used in nowadays applicaitons. Half-duplex is a legacy of history and not enabled unless there is a special need.
dw
