How to enable/disable CAN interrupts temporarily
embdev
First solution authored 25 sign-ins 10 replies posted
I use AURIX TC3XX. How can I enable/disable only CAN interrupts temporarily during CAN ISR processing?
Anupama_A
50 solutions authored 10 likes received 250 sign-ins
Hi @embdev ,
You could initially set the SRE bit to 0 and at the end of ISR, you can set it back to 1. Please let me know if it helps with your use case.
Nambi
50 likes received 5 likes given 100 solutions authored
Are you using MCAL or ILLD based driver?
Best Regards.
Anupama_A
Hi @embdev ,
embdev
@Nambi
iLLD
@Anupama_A
Do you mean the below code? But I have many interrupts enabled(RX, TX, error etc). So how can I disable/enable all? I don't want to use global interrupt mask.
ISR
srcPointer = IfxCan_getSrcPointer(config->can, config->interruptConfig.tefifo.interruptLine);
IfxSrc_disable(srcPointer);
IfxSrc_enable(srcPointer);
Nambi
SRE bit is part of the SRCx register of the CAN node. Setting "SRE" bit to 0 will disable all interrupts associated with that SRCx source register. IfxSrc_disable() sets "SRE" bit to 0.
You can make use of the SRE bit for the SRCx registers to which the interrupts you want to disable are mapped to.
Best Regards.
