I am using Aurix TC38 uC in one of the project. I am looking to modify MTU_CLC register to disable it for a negative test scenario.
However I cannot set DISR bit to 1 in WinIdea v9.21.103.
Is there anything that I have to do which enables me to edit MTU_CLC register?
Register is endinit protected, make sure that endinit is not set when you write to the register. I guess the winidea is not able to clear the endinit protection automatically when write to this register. Maybe check the winidea description if there exist a special handling for endinit protected registers.
