How to disable the Debugger access and recover it in Aurix2G
Jamber
25 replies posted 50 sign-ins First like received
I'm debugging the MBIST feature. When MBIST is running, access to related memory is not allowed. I can halt CPUs to prevent the access, but when a Lauterbach is connected, Lauterbach will access memory. It will often trigger XBar Error, so I want to disable the Debugger before MBIST, and recover the Debugger after MBIST. I can't find related information in usermanual, please tell me what I should do?
Thank you!
Best regards!
Di_W
500 solutions authored 1000 replies posted 250 solutions authored
Hi Jamber,
Lauterbach maybe give you a way to disable access XBar. https://www.lauterbach.com/pdf/training_aurix_trace.pdf
dw
Di_W
Hi Jamber,
dw
Jamber
Hi dw,
Thank you although I can't find relevant information. I'm tired to find IFX documents because it's too difficult. Just be it so, thank you.
