LucTung
Dear Infineon Technical Support Team,
Our plan is to connect TC397 to Marvell 88Q5152 through the RGMII interface to meet our application requirements.
In the past, on Linux systems, we have set up a fixed-link to specify the speed and duplex mode directly. We would like to inquire if a similar method can be used on TC397 to establish this connection properly.
At this point, we are still seeking more suggestions. We aim to ensure that our connection is both stable and reliable to fulfill the needs of our application.
Once again, thank you all for your help and support. We look forward to receiving more valuable advice.
Warm regards,
Di_W
https://www.infineon.com/dgdl/Infineon-TriBoardManual_TC3X71-UserManual-v02_01-EN.pdf?fileId=5546d46...
Hi Tung, please refer to section 3.11 "Ethernet" in the TriBoard user manual. You will find that the RTL8211FI-CG is used and the RGMII interface is used. You can refer to this design to suit your PHY chips.
