AURIX™ Forum Discussions
User14776
I purchased the program for the development board, and added the c file and the H file into the FrameWork,but can't compile .With the Tasking also I can't compile it.
How do I need to build a project to compile this program?
Thanks!
User13290
First solution authored
Hi Wan,
Thanks!
Can you show us a snapshot of the error message? It may contain a hint as to what's happening.
Henk-Piet Glas
Principal Technical Specialist
User14776
HIGHTEC.henk-piet.glas wrote:
Hi Wan,
Henk-Piet Glas
Thanks for your answer!
3232.attach
have set the path to the Tasking compiler and added the H file path in the project.
User13290
Hi Wan,
3232.attach
Looking at the error message I think what you may be missing is the --include-file option. Within their IDE TASKING uses it to automatically pre-include SFR files. In your case, although you are using IDE, you are probably calling an external makefile that is part of the IFX framework. The IDE itself therefore has no control over it and you will have to find a way to add this option manually.
Calling external makefiles from IDE is sometimes denoted as non-managed makefiles. Preferably you'd like to have managed makefiles instead. These are automatically regenerated as soon as you change a compiler, assembler or linker setting. So the trick is to migrate a non-managed makefile project to a managed one instead. If you'd like to know how this is done, just take a peek into this documentation. Using a step-by-step approach it shows you how to jump all the hurdles.
Henk-Piet Glas
User14776
Hi Wan,
Henk-Piet Glas
Thanks very much!
User13290
Aurix_wff wrote:
Thanks very much!
My pleasure. Happy to help.
Henk-Piet Glas
User14776
Henk-Piet Glas
Thanks for your help!
First, I'm very sorry,my English is poor!
I follow your documentation, create a new project, add a Demo, and finally compile successfully.
I have learned a lot of knowledge.
3241.attach
User13290
Hi Wan,
That's brilliant! Happy to read you're making progress.
Henk-Piet Glas
