Sep 15, 2019
03:54 AM
Sep 15, 2019
03:54 AM
Hello, every one.
I found some problem after reading the "TriCore DSP Optimization Guide Part 1", in Page169:
For Example, the "Example 1"
mov.u d2,#16
L: add d1,d1,d0
ld.w d0,[a3+]
add d2,d2,#-1
jne d2,#0,L
"mov.u" is 1 cycle
"add d1,d1,d0" and "ld.w d0,[a3+]" is parralle, so is 1 cycle
add d2,d2,#-1 is 1 cycle
jne d2, #0, L is 1 cycle
So, the total is: 1 + 4 * counter
but the document said:2*(counter-1)+3+2*counter
why?how to figure it out?
Another problem:
"ld.w d0,[a3+]", how to caculate the cycle of [a3+]?
waiting for replying.
mov.u d2,#16
L: add d1,d1,d0
ld.w d0,[a3+]
add d2,d2,#-1
jne d2,#0,L
"mov.u" is 1 cycle
Another problem:
09:38 PM
Sep 20, 2019
09:38 PM
Is there anyone would like to tell me?
Sep 23, 2019
02:35 AM
Sep 23, 2019
02:35 AM
Hi Shaquille,
Here's the table I used:
[IP] L: add.w [1]
[LS] ld.w [0] /* chapter 13.1.2 */
[IP] add [1]
[BR] jne [2 or 3] /* chapter 13.6.1 */
The ld.w instruction makes for a dual issue instruction. So combined with add.w it counts 1 single cycle. The jne instruction is two cycles when jumping backwards, and three cycles when evaluating to false. I left out the mov.u instruction because I think the focus was on the branch and not the preliminaries. This then results in the following calculous:
cycles = (count-1)*(2+2) + 1*(2+3)
= 2*(count-1) + 2*(count-1) + 2 + 3
= 2*(count-1) + 2*count + 3
So using words, for n iterations there are (n-1) of taken branches. And there is always 1 branch that will not be taken. The former is 4 cycles, the latter is 5 cycles. If someone can confirm or refute, that would be helpfull.
Henk-Piet Glas
Principal Technical Specialist
Embedded Software
