FD_aurix
100 sign-ins 100 replies posted 5 solutions authored
Hi
Is it possible to activate multiple SR on a single end of conversion event?
For example I want to activate a DMA transaction (e.g. connected to SRC_VADCG8SR0) and a SW interrupt (connected to
SRC_VADCG8SR1)
µC_Wrangler
50 solutions authored 100 sign-ins 25 likes received
Not directly, but you can achieve a similar result with fancy DMA: create a transaction set that writes to another DMA channel's CHCSR.SCH, and then the completion of that DMA channel could trigger the software interrupt.  Or, you could link to another TCS that writes to the interrupt router to trigger the interrupt.
µC_Wrangler
