User18303
Hi all,
How many channels can ADCs(EVADC) be synchronized for parallel conversion ?
Kind regards,
Lina
#8042000 19535
User18237
Hi Lina,
Up to 4 ADCs in a synchronization group can be exactly synchronized for parallel conversion.
And in case of over 4 ADCs, they can be almost synchronized if the same ADC trigger source input to each ADCs.
“Almost synchronized” means there are variations of each ADC start timing with the range of a few cycle of analog clock(fADC).
Kind regards,
Mr. AURIX™
