AURIX™ Forum Discussions
User18151
First solution authored
Hi AURIX Community,
do you know how many SENT channels can support SPC (Short PWM Code) protocol?
Thank you!
Christine
#8042000 13459
User18237
Hi Christine,
All of SENT channel can support SPC protocol, but some of SPC outputs may not be connected to pins depending on the package. For more details, please refer to the data sheet for each device.
E.g. For TC233 (TQFP100), only SPC output of SENT channel 1 (SENT_SPC1) is connected to a pin. Other SENT channels can not output SPC protocol.
Mr. AURIX™
