Nov 06, 2019
02:32 AM
Nov 06, 2019
02:32 AM
Hi AURIX Community,
how do I synchronize operations between CPU cores?
Thanks and regards
Christine
#8042000 19639
Thanks and regards
Christine
#8042000 19639
03:00 AM
Nov 06, 2019
03:00 AM
Hi Christine,
The TriCore and the AURIX internal buses support atomic (read-modify-write) instructions and transactions.
See Atomic Transfers in the User Manual, and application note AP32350: AURIX Multi-Core Software Development.
Atomic instructions are generally used to implement multi-core primitives such as semaphores and locks/mutexes.
The Interrupt Router also has a Service Request Broadcast feature that can trigger multiple service requests (interrupts) at a time.
However, due to CPU interrupt priorities and Interrupt Router arbitration, SRB interrupts will not trigger at exactly the same time.
Mr. AURIX™
Mr. AURIX™
Mar 16, 2021
06:25 AM
Mar 16, 2021
06:25 AM
Hello Support,
In the source code for AP32350: AURIX Multi-Core Software Development.
I am unable to find DSYNC instruction being used anywhere.
Can you please provide me a completed source code where DSYNC instruction is being used for AP32350?
According to the following Errata Item Hint: "CPU_TC.H019 Semaphore handling for shared memory resources"
DSYNC must be used.
Best Regards
DSYNC must be used.
Best Regards
