AURIX™ Forum Discussions
User17740
First like received
Hi Aurix Community,
could you please help with the following: how do I access another core's memory?
Thank you!
Bernie
#8042000 19638
User13290
First solution authored
Hi Bernie,
I'm guessing you're referring to access to either DSPR or PSPR type memories. Each vendor has their own way of doing things. If you are using TASKING then you may want to study chapter 1.4.4 of the user manual. If you are using HighTec then chapter 19.3 explains how to do it at link time.
Henk-Piet Glas
Principal Technical Specialist
Embedded Software
User18237
Hi Bernie,
By default, the AURIX is wide open: all bus masters can access all memories. It is up to your application to restrict access using these mechanisms:
Each CPU can restrict its own access via the Memory Protection Unit
Each CPU's Safety Memory Protection can protect the CPU's local memories from access by other bus masters
Register Access Protection permits access to memories and peripherals from bus masters
Mr. AURIX™
