DownyK
100 replies posted 10 solutions authored 250 sign-ins
Hi
I want to modify the function that is called when a trap occurs.
The trap I want to modify is to be precise, the ESR1 trap.
I'd like to ask what doc should I read to find out which functions are called when a trap occurs, or information about the trap.
I am using TC387AE.
Thanks in advance.
Dawoon kim
Di_W
500 solutions authored 1000 replies posted 250 solutions authored
Hi Kim,
AURIXTC3XX_um_part1_v2.0.pdf,  Section 9.2 Trap Gerneration (TR) describes the TRAPSET TRAPCLR TRAPSTAT TRAPDIS registers which are for ESRx pins' transition to trigger a CPU trap.
Section 9.1.4 Exnternal reset sources and indications, which describes ESR pin functions: reset request trigger / wakeup trigger / reset indication output / trap request trigger
https://www.infineon.com/dgdl/Infineon-AURIX_CPU_Trap_Recognition_1_KIT_TC397_TFT-Training-v01_00-EN...
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/CPU_Trap_Recognition_1_KIT...
About code,  I will reply you if I got any.
dw
Di_W
Hi Kim,
dw
