AURIX™ Forum Discussions
User19005
Hello, I'm trying to use CAN by using iLLD.
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/MULTICAN_1_KIT_TC297_TFT
please ignore this question. problem is addressed
teoBits
100 replies posted 50 replies posted 25 replies posted
Hello syjung,
to port the example, first verify that your device supports the module you want to use (in this case you should be ok). Then, you can create a new project for the TC27X device or for the KIT_AURIX_TC277_TFT board and copy-paste the GitHub example's files inside (MULTICAN_1.c/.h), together with the needed instructions on the Cpu0_Main files. This ensures that in the new project you have everything correctly configured for your device (all the iLLDs, the linker files, etc.) .
After that, check if in your board/device the pinouts are different and modify the example accordingly.
teoBits
