AURIX™ Forum Discussions
User17897
In , there are some description as following:
The following additional documents are also available for download from the TriCore Architecture and Core section:
TriCore® DSP Optimization Guide.
TriCore® EABI (Embedded ABI) User’s Manual
TriCore® Compiler Writer’s Guide
But, I cannot find "TriCore® DSP Optimization Guide" and "TriCore® Compiler Writer’s Guide" in Infineion's website.
where and how to find them?
cwunder
Did you try Google?
TriCore DSP Optimization Guide - Part 1: Instruction Set
https://www.infineon.com/dgdl/sj1001366.pdf?fileId=db3a304312bae05f0112be6e62be0102
TriCore DSP Optimization Guide - Part 2: Routines
https://www.infineon.com/dgdl/sj2004284.pdf?fileId=db3a304312bae05f0112be857b56010f
TriCore Compiler Writer's Guide v1.4 December 2003
https://www.infineon.com/dgdl/inf0010_v1_4Dec2003_1.pdf?fileId=db3a304412b407950112b40f8aad1423
User17897
Thank you, I've found them.
However, I noted someting details:"Edition 2003-01"
I know, many features have changed for TirCore's Instruction Set from 2003 to 2019,
So, The above link is the latest version ? How Can I found the latest version?
