User17615
First like received
Hi all,
How can AURIX™ communicate with Xilinx FPGA devices?
Tita
#8042000 13387
User18237
Hi Tita,
There are two ways to interface AURIX™ to Xilinx FPGA
1. For AURIX™ derivatives with on-chip HSSL (*H*igh *S*peed *S*erial *Li*nk) module, Xylon, a Premier Member of the Xilinx Alliance Program, offer logiHSSL IP core or “LogiHSSL HSSL Slave Controller” to enable the interface HSSL with certain XILINX FPGAs. More information on this topic can be found in the following website: https://www.logicbricks.com/Products/logiHSSL.aspx.
Xylon also provides a development kit to support the relevant design work: www.logicbricks.com/products/logiHSSL-ZU.aspx.
2. For AURIX™ derivative with on-chip EBU (External Bus Unit) Unit, EBU can be used as for this purpose.
Mr. AURIX™
User20382
Maybe you can find the answer in FPGAKey, FPGAkey is the trusted Industry Network for FPGA(CPLD) design and manufacturing, we provide technical articles, tutorials, wiki, and over 80,000 FPGA devices.
NeMa_4793301
Level 6
Level 6
"Maybe"? It's a bit spammy if you don't provide specific links to solutions that help an FPGA interface with an AURIX microcontroller.
User20382
https://www.fpgakey.com/productfamily/#xilinx
