04:25 AM
Sep 24, 2014
04:25 AM
as the subject says, I'm looking for an example project for the TC234 TriBoard which can be used with the Hightec Free Entry Toolchain.
It seems that the latest version downloaded yesterday even does not contain the header files for this controller.
04:37 AM
Nov 07, 2014
04:37 AM
Even I'm facing the same problem, even to do it with Tasking is difficult.
Jan 07, 2015
10:46 AM
Jan 07, 2015
10:46 AM
The latest version supports the TC23x.
http://free-entry-toolchain.hightec-rt.com/
Version 4.6.5.0-infineon-1.1 (includes support for AURIX TC29x, TC27x, TC26x, TC23x and TC22x)
10:27 PM
Jan 22, 2015
10:27 PM
hi !
could you get the example code TC234 Application kit
Srividya
Srividya
03:43 AM
Mar 25, 2015
03:43 AM
I also would like to have the example program of the TC234 TFT App kit in code. It's hard to guess the frequency of the display frames for examples etc.
best regards
Dan
best regards
Dan
Oct 28, 2016
07:03 AM
Oct 28, 2016
07:03 AM
I want start the TC1724 programming and want to know what is best compiler for TriCore32Bit MCU?
Tasking Or Hightec?
Tasking Or Hightec?
04:55 PM
Oct 28, 2016
04:55 PM
Tasking Or Hightec?
I want this too.. but I guess it Hightec
10:54 PM
Oct 28, 2016
10:54 PM
what? what you mean??? lol
Nov 06, 2016
11:47 PM
Nov 06, 2016
11:47 PM
ِDo Hightec Compiler have the simulator for TriCore MCU? If have not !how can i simulation my code for TC1724N? Be sure to have hardware and debugging tools?
11:47 PM
Nov 06, 2016
11:47 PM
Why don't you give both a try and decide for yourself?
Keep in mind that these are more or less restricted "free" editions and may not represent the full release in terms of features and performance.
Edit: I just saw that you're using a legacy TriCore and not an AURIX. We just support the AURIX with the free lite edition, our full release of course supports all available devices.
May 03, 2017
04:47 AM
May 03, 2017
04:47 AM
Hi.
do you know how generat hex file in the the HighTec compiler?
05:56 PM
Jul 27, 2017
05:56 PM
hi !
Alan
Alan
Dec 27, 2017
12:57 AM
Dec 27, 2017
12:57 AM
Hi Jan.
How can i use TSIM simulator to simulation the input IO for Tricore MCU?
how to create a input simulation file?is there a form to show the analog signal in TSIM?
thanks.
thanks.
Dec 29, 2017
07:37 AM
Dec 29, 2017
07:37 AM
Hi Hemn,
Have a look at chapter 22.2 of our user guide, having title "functions in libos.a". It explains tsim simulated I/O calls are supported including a use-case example. While the use-case example makes use of low level functions such as open, read and close, this should also work for higher level functions such as printf and scanf.
Henk-Piet Glas
Principal Technical Specialist
hemn wrote:
Hi Jan.
thanks.
Henk-Piet Glas
