公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
朴素
First question asked First reply posted
申请了免费的HighTec编译的时候提示以下错误是什么原因?按照网上的教程安装的,还请大神不吝赐教。 **** Model validation **** Generel error during the generation Possible reasons are: 1. A copy of a derived file exists in the target folder 2. You have no write permission in the target folder. **** Model validation ****
0 点赞
1 解答
orson1
如果这样看你的licences是不绑定了以前的那台电脑
在原帖中查看解决方案
0 点赞
9 回复数
JCET-GAO
Distributor - Jingchuan(GC)
100 comments on blog 50 comments on blog 25 comments on blog
可以试试收费的
0 点赞
朴素
个人用^-^
0 点赞
orson1
和你的demo程序有关的吧,你用的是模型开发?
0 点赞
朴素
不是,之前调试通过的。这次换了台电脑,安装上申请的这个licences就这样了。
0 点赞
orson1
0 点赞
ZERO_GO
Level 6
Level 6
5 sign-ins Welcome!
mark
0 点赞
阳东
10 comments on blog 5 comments on blog First comment on blog
mark
0 点赞
liliWinner
Level 6
Level 6
500 replies posted 250 replies posted 100 replies posted
换个license
0 点赞
User22064
10 sign-ins First like given 5 sign-ins
关注一下
0 点赞
