gururaj1
I would like to configure Hardware controlled interrupt. Could you please some one help me here with sample code
Nambi
5 likes given 100 solutions authored 250 replies posted
The above interrupt example is about triggering the interrupt from hardware pin and handling the ISR by the CPU.
Your use-case is unclear here. An interrupt can be either serviced by CPU or DMA based on the configured TOS.
Best Regards.
