Jan 24, 2023
03:34 AM
Jan 24, 2023
03:34 AM
I am using High-Tec Ide for compiling code for TC39X controller, in that Hardware interrupts is not working,
how to map hardware interrupts in linker file
07:53 AM
Jan 25, 2023
07:53 AM
Kindly make sure that you have configured the Base Interrupt vector as per the Aurix TC3xx Hardware User Manual and Architecture Manual.
You can also refer to any of the code examples in the link below:
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples
Aiswarya.
