Apr 29, 2020
12:36 PM
Apr 29, 2020
12:36 PM
Hello Support,
In the TC2xx Hardware Design Guide App Note :
https://www.infineon.com/dgdl/Infineon-AP32469_TC2xx_hardware_design_guide-AN-v01_00-EN.pdf?fileId=5...
It is mentioned that OCDS should be disabled in the production ECU.
Question is what is the hardware and software design to implement OCDS disable feature is not described.
Can you please elaborate more about this sentence so that we can perform the this task of "OCDS Disable" effectively in the production environment?
Best Regards
Best Regards
04:28 PM
Apr 29, 2020
04:28 PM
OCDS is disabled by default, but it is possible to activate OCDS via software. For production software, keep OCDS disabled so it can't interfere with regular operation.
