What should be the pull Up values for the HWCFG pins, The pull down was mentioned to be below 4.7k, it is same for pull up resistors for the HWCFG pins as well?
1. Could you let us know the device under discussion? (eg: TC275, TC397)
2. Are you referring to the internal or external pull-up?
3. Which document and section are being referenced for the below statement?
"The pull down was mentioned to be below 4.7k"
Best Regards.
Apologies for not providing the entire background.
1. The device under discussion is Aurix TC397XX.
2. External Pull Up.
3. "TC2xx hardware design guide" this was the document I was looking into.
I have also added the screen shot from the design guide.
Thanks!
For external pull-up a value higher than 4.7K can be used without any issue.
Prudhvi.
