Thomas02
First question asked Welcome!
If OCSD is Clear and DBGLCK is Set. we have to correct  password , all UCBs are confirmed state. Can we connect the ECU with JTAG?
Karishma_S
First comment on blog 250 sign-ins 25 likes received
Hi @Thomas02,
If OCDS is clear and DBGLCK is set, you can connect to the ECU via JTAG by providing the correct password.
You can either use the MemTool/PLS GUI or use the 'disable protection' command sequence in your user code to connect to the ECU.
Karishma_S
Hi @Thomas02,
