AURIX™ Forum Discussions
User19665
First like given First reply posted First question asked
Hello all,
What will be the correct way to set Vector Table Offset Register (VTOR) in HSM Bootloader?
According to ARM's documentation, Cortex-M3's VTOR definition [31:7]TBLOFF, [6:0]Reserved
https://developer.arm.com/documentation/dui0552/a/cortex-m3-peripherals/system-control-block?lang=en
If Bootloader would like to re-direct application to S16 area, is below the correct way of setting VTOR?
#define MEM(memAddr) (*((volatile unsigned int *)(memAddr)))
#define APPLICATION_BASE 0x80060000ul
MEM(0xe000ed08ul) = APPLICATION_BASE;
dw
Dear customer,
For security reasons this module is described in a separate documentation. Please contact your Infineon
representative for further information.
dw
dw
Dear customer,
dw
