AURIX™ Forum Discussions
User17838
I am working on TC264 Project using Eclipse + Rt-druid v3 and TASKING Compiler.
As known, we can only flash th eexecutable .hex file to AURIX TriCore board.
Could you help me please generate the hex file in order to flash the program?
Thank you.
User17838
Anyone to help ?
Thank you in advance.
VincentWan
First like received 25 replies posted 10 replies posted
Hi
You should refer Tasking user guide / manual.
3716.attach
VincentWan
Linker option with command line syntax
3717.attach
