I'm trying to use the Ethernet-Module of the TC397 on TriBoard TC3x7 TH V2.01 an can't get it to work. I used the example code shown in the header of IfxGeth_Eth.h
Did anyone managed to use the Ethernet on this processor and can provide a working example code?
User18226
When you mean not working, did you mean you cannot see any packets coming out or meant the code itself doesnt run? I have network connection issue. I see the code running but I cant get the triboard to connect to my PC for packet capturing. Could you figure out a solution to your issue?
User18844
Hi NickP,
I had the same issue. Have you got your issue resolved? If so, can you please let me know how to resolve it? Thank you.
yp10
First reply posted First like given Welcome!
Can you refer to Ethernet_1_KIT_TC397_TFT Demo in ADS.
Other demos are GethBasicDemo, Ethernet_1_KIT_TC375_LK,..
