Enthusiaser
5 replies posted 10 questions asked 25 sign-ins
I have aurix evaluation board for Infineon A2G  TC375LK kit, as per my understanding board is having inbuilt debugger.
I am using Minwiggler debugger. But while i am trying to debug, its giving error.
Is this debugger requires any license? Please provide detailed information.
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @Enthusiaser
I guess the issue is related to the hardware itself.
I'd like to suggest you check the hardware configuration of the on-board debug by referring to the user guide of the evaluation board.
BR,
Jeremy
Jeremy_Z
Hi @Enthusiaser
According to your description, you use an external debugger: Minwiggler instead of the on-board debugger to debug the TC375LK kit, is it right?
Further, can you enter the debug mode if you use the on-board debugger?
BR,
Jeremy
Enthusiaser
Hello
Thanks for your quick reply.
I am using on board debugger. But while debugging i am getting error.
can u check the screenshot that i have attached here.
Jeremy_Z
Hi @Enthusiaser
Firstly, I'd like to know if the debugging action worked well before.
Next, do you encounter a similar error if you use the TASKING C/C++ Debugger to debug?
BR,
Jeremy
This is first time i am using Minwiggler. I am not facing such issues with Tasking C/C++ Debugger.
Jeremy_Z
Hi @Enthusiaser
I was wondering if you could list the steps for replicating the debug error, as it can help me to figure it out.
BR,
Jeremy
Jeremy_Z
Hi @Enthusiaser ,
How're things going?
BR,
Jeremy
Jeremy_Z
Hi @Enthusiaser
BR,
Jeremy
