AURIX™ Forum Discussions
BluewindAZ
First question asked Welcome!
Dear all,
I'm looking for information about the Generic Bootstrap Loader (via CAN) on AURIX devices.
First, I'm not able to find an application note for AURIX similar to the one existing for XMC:
https://www.infineon.com/dgdl/Infineon-AP32269_XMC4000_CAN_BSL-AN-v01_00-EN.pdf?fileId=5546d4624933b...
can you suggest a similar application note for Aurix?
Second, what hardware & software tools are available to program the code using the Generic Bootstrap Loader via CAN?
Alessio
TBencher
First like given 50 sign-ins 10 solutions authored
Hi Alessio,
you can find related information inside the Target Specification file under "CAN Bootstrap loader".
I am not quite sure about the tools, but if you look inside the documentation every single message is well described. Even the program flow is clearly explained in "CAN Bootstrap loader flow". The only thing you need is a CAN controller+transmitter. You could use for example an additional AURIX-evaluation board or -triboard to build that CAN bridge. That is up to you.
TBencher
FD_aurix
10 likes given 50 sign-ins 10 questions asked
Hi TBencher
Could you please specify the name of the file? I've checked into the ones listed on myicp under Target specification but there is no reference for the bootstrap loader.
TBencher
Hi FD_aurix,
sorry for late response. Just look inside AURIXTC3XX_ts_part1_v2.5.1 file.
TBencher
FD_aurix
Thanks!
