Hi Community,
my Goal is to trigger a series of Channels of the Group 0 of the EVADC. G0 is the master for the slaves in G1.
For that i'm using 3 ATOM CHs. Each ATOM CH has two Trigger. Each ATOM gets assigned to AdcTrig0, 1 or 2.
Each AdcTrig is assigned to one Queue. With each Queue i want to trigger up to 4 Channels. The Channels have to be assigned to up to 2 Queues.
For Testing i added G0CH0 and G0CH1 to Queue0 and Queue1. After adding the interrupt for G0CH1 the interrupt of G0CH0 is not issued anymore.
Does anyone know the issue and how to fix it?
Here is my Code for two Channels:
That is the signals i measure through an Oszilloscope.
Blue: ATOM CH 4
Red: ATOM CH 5
Green: GPIO Toggle through Interrupt G0CH0
Yellow: GPIO Toggle through Interrupt G0CH1
Violet: GPIO Toggle through Interrupt G1CH0
Thanks in advance
Andreas
AURIX
could you please provide a small block diagram as well?
TBencher
could you also provide your MCU type and GTM configuration?
TBencher
The Problem was, that in this table the Atom/EVADC wasn't connected
