GTM phase shift issue
User20162
10 replies posted 10 questions asked 5 replies posted
i am using GTM Tom module in aurix tc377, i am trying to do the phase shift, i can able to acheive the phase shift till 90 degree, how can i acheive 180 degree phase shift. does we have any limitation for phase shift.
i am not using any DTM to do phase shift, i am converting degree to time and add it to the shadow register of respective Tom channel.
in tc377 i am configuring GTM cluster clock as 100MHZ but while reading the TOM clock it is showing 50 Mhz, where to disable the clock divider??
Mohamed Rahmathulla
User22142
First like received First solution authored
Dear Mohamed,
Could you post your code so we can see and try to help?
nsyed
5 likes given 100 sign-ins 50 sign-ins
For setting the correct clock frequency for GTM module. I would recommend you start by taking a look at below registers
CCU module - CCUCON0[GTMDIV]
GTM module - CMU_GCLK_NUM, CMU_GCLK_DEN and CMU_CLK_CTRL
TOM module - TOM_TGC_ACT_TB
Good luck.
User22142
Thanks for pointing me in the right direction, but I think it would be more efficient if we saw your work in text 😉
nsyed
There are several examples available for Infineon in below link .
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples
Obviously these examples are most useful use cases.
Daniel27
5 questions asked 10 sign-ins 5 replies posted
Hello, can you post your code here? I trying to do phase shift but I don't know  how, I create 4 pairs of Pwms with deadtime using GTM and DTM submodule but for phase shift I don't know how to use. If you don't want to share the code can you tell me what you use to create these phases shift?
Thanks in advance!!
