AURIX™ Forum Discussions
User17459
5 replies posted First reply posted First question asked
Hi, where can i find some example of this function? I do not see any information about it in this forum.
User17459
???? :confused:
teoBits
100 replies posted 50 replies posted 25 replies posted
Hello Juanjqh,
I don't know about examples for the Engine position in particular, but if you are looking for examples for the GTM module, you can take a look at the GTM_ATOM_Interrupt_1, GTM_ATOM_PWM_1, GTM_TIM_Capture_1, GTM_TOM_Interrupt_1 and GTM_TOM_PWM_1 code examples!
They also comes with a dedicated tutorial for each of them: GTM_ATOM_Interrupt_1 tutorial, GTM_ATOM_PWM_1 tutorial, GTM_TIM_Capture_1 tutorial, GTM_TOM_Interrupt_1 tutorial and GTM_TOM_PWM_1 tutorial.
If you are interested in other modules and you want to start programming for AURIX™, you can get the new Integrated Development Environment (IDE) here: AURIX™ Development Studio and get inspired by numerous trainings from here: AURIX™ Trainings.
If you are not familiar with Eclipse based IDE’s checkout the Getting Started guide!
Hope it helps,
teoBits
User17459
Thanks for you reply teoBits, i will try this example. 😉
