- Email to a Friend
Hi all,
I went thru the example and verify the signal and varying different frequencies and it is work perfectly fine for my eval TC37x board
I then tried to change the input pin to #define PWM_IN IfxGtm_TIM1_1_P02_1_IN with the expectation if I changed the CMU_CLKEN_CLK1, I will get the same result
IfxGtm_Cmu_enableClocks(&MODULE_GTM, IFXGTM_CMU_CLKEN_CLK1); /* Enable the CMU clock 1 */
But my g_measuredPwmFreq_Hz = +Inf
and g_measuredPwmDutyCycle = NaN
The data sheet calls out the CMU_CLK0, CMU_CLK1, CMU_CLK6, CMU_CLK7 are used for the TIM filters counters.
What did I do wrong or assume changing the input pin to TIM1 and enable the CLK1 will not work in this case?
- Email to a Friend
In the example, inside the function IfxGtm_Tim_In_initConfig(), the configuration is for TIM0 CH0
config->timIndex = IfxGtm_Tim_0;
config->channelIndex = IfxGtm_Tim_Ch_0;
IfxGtm_TIM1_1_P02_1_IN corresponds to TIM1 CH1. This is a conflict. Can you check?
Nambi.
- Email to a Friend
Nambi.
- Email to a Friend
Hi Nambi,
Thank you for pointing out my mistake
After changing to
config->timIndex = IfxGtm_Tim_1;
config->channelIndex = IfxGtm_Tim_Ch_1;
The result is not there yet
I also need to change
config->capture.clock = IfxGtm_Cmu_Clk_1;
In order to get the Frequency and Duty Cycle correct show in the debug.
However, is this a coincident or the capture module actually don't care about the timeout and filter's clock because I purposely tested by left the unchanged such as
config->timeout.clock = IfxGtm_Cmu_Clk_0;
config->filter.clock = IfxGtm_Cmu_Tim_Filter_Clk_0;
And I still get the good results?
- Email to a Friend
Hi Nambi,
Continue to explore this project.
I now want to see if I am able to capture the slower frequency like in 1 to 2 Hz.
I changed the TOM to tomConfig.clock = IfxGtm_Tom_Ch_ClkSrc_cmuFxclk4;
and #define PWM_PERIOD 872 /* PWM signal period for the TOM */
I verified on the scope the Frequency out put from the TOM is 1.75Hz
But my g_measuredPwmFreq_Hz = 14.67191
and g_measuredPwmDutyCycle = 173.07
Is this the problem with capture clock either CMU_CLK0 or CMU_CLK1 that too fast for the lower frequency capture?
- Email to a Friend
Hi Nambi,
Please disregard the question since I solved the issue.
For anyone try the same exercise, as my guessing I tried to slow down the clock for TIM to 1MHz with the setting new frequency and I got the capture work correctly to capture 1.7Hz range
#define CMU_FREQ 1000000.0f /* CMU clock frequency */
IfxGtm_enable(&MODULE_GTM); /* Enable the GTM */
IfxGtm_Cmu_setClkFrequency(&MODULE_GTM, IfxGtm_Cmu_Clk_0, CMU_FREQ); /* Set the clock frequency */
IfxGtm_Cmu_enableClocks(&MODULE_GTM, IFXGTM_CMU_CLKEN_CLK0); /* Enable the CMU clock 0 */
