i am sampling frequency channel in 10 ms task. i am only able to read frequency above 100 Hz. if signal frequency in frequency channel is less than 100 hz, i am able to observe drop in signal measurement.
is there any way to increase lower frequency capture range other than sampling at higher time slice?
Thanks in advance
Aurix
- frequency
Can you provide more details on what product and what block is used here?
i am using Icu_17_TimerIp_GetDutyCycleValues() API to read frequency channel.
Channel Configured for signal measurement and GTM Cluster Freq=50 Mhz.
Looking forward for your reply
I see this is related to MCAL which is not discussed in the community.
