Hello all,
I am new to Infineon and FreeRTOS and I am currently planning to run FreeRTOS on Infineon TC397 ADAS board. I am facing compiler and linker errors while building the demo code by FreeRTOS (RTOS demo project for Infineon TriCore TC1782 using the HighTec GCC compiler and PLS UDE debugger un...) in order to modify the code to TC397. Please help me in getting a FreeRTOS demo code for TC397 which can be compiled using HighTec IDE.
Can you check out the thread in following link?
https://community.infineon.com/t5/AURIX/FreeRTOS-for-AURIX-TC375/m-p/381648#M9596
